SunnyHouTX
SunnyHouTX's Avatar
02.17.2009, 03:02 PM
If you go with a standard spur/pinion set up, be prepared for stripped spur gears. The direct drive set up eliminates that, and you will only have to change tire diameter and motor Kv. Motor Kv only if nothing else makes the car go faster.
