TexasSP
Something, anything, nothing
TexasSP's Avatar
02.17.2009, 05:56 PM
I want the 10-12s capability for a speed run car, and it would be nice for 5th and 1/4 scale conversions. I do agree that I am happy with 6s for 8th scale applications.
www.cubicle101.com
Sammus
Sammus's Avatar
02.17.2009, 08:52 PM
If you just want to do speed runs get one of those chinese air escs (turnigy hv sentilon comes to mind). theyre fine if you have mech brakes and dont mind what feels like 100000% punch control (ie very soft start). The soft start isn't a problem if you're just trying to go fast in a straight line :).
PS I have a HV (12s 100A) sentilon for sale if you want, pm me.
sikeston34m
sikeston34m's Avatar
02.22.2009, 01:58 AM
I have a pair of 3500mah 4S 30c - 50C packs that will fit the E Revo or the E maxx.
This makes for a 8S setup that will push 105 amps continous, 175 amps Burst.
I've been running them parallel to make 4S at 7000mah.
I would like to see this coupled with a 1100kv 80mm Medusa on 8S.
Efficiency out the wazooo.
Yes there are other options, but to compromise and settle for anything less would be a crime.
The MMM software is unbeatable.
02.22.2009, 02:32 AM
Damn, you sound like a copy cat... I currently have a pair of fp 3700 25c 4s lipos wired in series with a lutach 10s esc and an axeox 36/38/2 (1200kv or so). Not the lightest truck (bombproof emaxx with lst diffs) and this setup works well. The aveox is more 1515 size, and an 80mm medusa would be a good upgrade. I will be prating this truck to finish some other trucks. Flm savvy will get the esc, and a 3200 30c 10s pack to go with a 1521 2y (780kv). The chassis will replace the plastic chassis on the 6x6 maxx (I have 2 torpedo chassis) with the 2826/12 axi on 4s. The suspension with the lst diffs will mate with a 3905 emaxx chassis and tranny with a plett maxx on 4s with a MMM.... Time to get all of my MTs running! By next sat the hobby room will be reconfigured and I can start working on stuff again... I have spent the last month building lipos and selling!
MetalMan
MetalMan's Avatar
02.23.2009, 01:53 AM
You guys are both copy cats! I've been running 8s 3700mah 20C, Medusa 36-80-1100, and LT-10s ESC in my Savage for well over a month now. HUGE POWER. Literally the truck will wheelie at 35mph+ no problem despite the extended chassis, center diff (leaked out a bunch of its 100,000wt oil), and near-12.5lb weight. The shape the front tires achieve is just unreal.
However, the motor does tend to get a bit on the hot side, I think upwards of 160 deg. F. ESC and batteries hardly heat up, and the truck is geared for ~45mph. Could it be this motor is undergeared? If so, all I have to say is
02.23.2009, 03:46 AM
Not to point fingers but my emaxx has been running since november...
So the 80mm gets warm. I guess try to gear it up... I will be interested to see what happens.
