jayjay283
jayjay283's Avatar
02.18.2009, 12:55 PM
I use the dremel, 3/32nd diamond tip to cut around the main outlines, then use the larger sanding drum sander to square it all up. Only takes 20 minutes, but you get plastic shreddings everywhere.I never could use the body scissors, always cut too far and ruined the body
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
02.18.2009, 01:39 PM
If you have a steady hand with a hobby knife, put a new blade in, and score along the line of the wheel well of the body, or the lines you draw with a sharpie. You want to score the Lexan deep enough so that it will cleanly snap off when you bend it at the score. That's how I've been doing it for years. In my on road days, I used an OLFA circle cutter as the wheel wells for on road cars are mostly perfectly round like the wheel itself. I still use my OLFA circle cutter to make vent holes.
That is just another way of doing it.
No brain, no headaches.
Sanding drum?
alangsam
Sanding drum? - 02.18.2009, 02:59 PM
Is the sanding drum the one with a bunch of small squares attached to the center and its in the shape of a circle maybe 1"-2" diameter?
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
02.18.2009, 02:03 PM
+1
I rough it out as close as I can, and then use the large sanding drum. The radius gives you nice even corners, and it looks great. I've used it to fix other people's bodies that were a little rough. Probably want to do this outside though, as it is pretty messy.
