pasan
I <3 RC
pasan's Avatar
02.19.2009, 12:35 PM
Originally Posted by FDK8776 View Post
Really there are multiple questions.
1. Fan comes on earlier than 150 degrees, is this okay? Yes
-Will I see a short life on my ESC due to the fan constantly running? No, electronics like it when things are cool. It's not like a car where an ideal operating temperature is required. With electronics, the colder it is, the better they perform.
2. If this is happening at such a low gearing ratio, will I be creating problems by gearing up? This is a void issue if you're confident that the fan is triggered at a lower temperature as opposed to the ESC heating up quicker.
3. Since I'm here asking questions, what should the motor temps be? I'm at 120 degrees right now. Again, with gearing up, will I be creating issues with over-temp? This is always a trial and error thing as there are several factors coming into play. I use 22/58 gearing on 6S in my E-Revo, and the motor has the novak 5412 heatsink with two highspeed cooling fans mounted on it. Couple that with 15 degrees of advanced timing and my temps are never more than 140F.
Thanks.
I've added my 0.02 inline
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
