11.07.2005, 01:24 AM
Hi,
Here is a preview pic of the work in progress motor bracket I am thinking of using for the buggy conversion. Basically, because I want to use the mechanical brake, I have to make an extension shaft so that the motor will not interfere with the rear brake disc. This complicates things a little.
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
11.07.2005, 01:25 AM
hmm, pic didn't turn up. Let's try again
11.07.2005, 07:05 PM
that is a lot more manufacturing then the savage motor mount. looks good.
Are you going to be running a 2 speed? is that why you are going to use the mechanical break? and i sent you an email too.
11.07.2005, 09:03 PM
Hi,
Mechanical brake is just personal preference. Not evenn sure whether it is better or not.
Regards,
Joe Ling
11.16.2005, 10:30 AM
Some updates of this project. I have just received the motor mounts in pieces & done a loose fit to see if everything is ok. Here are some pics.
Regards,
Joe Ling
11.16.2005, 10:31 AM
more pics
11.16.2005, 10:32 AM
more
11.16.2005, 12:57 PM
Great work Joeling!! you made it yourself? or was it made by mr constructor? good to see, you used a bearing to hold the long shaft..
11.16.2005, 07:52 PM
hi Serum,
Thanks for your comments. I had a local machinist fabricate this for me based on my crude drawings.
The bearing used is the type used in nitro engines. I figured that with the extension shaft, I need the extra support at the other end. This was done out of neccessity.
I am using 15T pinion & 46T spur. I think this is too tall a gearing. I cannot seem to locate my 14T pinion. So I am trying to get some from Mike. I think I will switch to 13T while I wait for the 14T. What do you think ?
Regards,
Joe Ling
11.29.2005, 10:17 AM
Hi,
The conversion is nearly done. Still waiting for the battery straps (hint hint Mike) & body need to be painted & the cooling fan battery need to be attached.
Regards,
Joe Ling
11.29.2005, 10:20 AM
more pics
11.29.2005, 10:21 AM
more
12.04.2005, 03:20 PM
Your project looks sweet. That Mr. Constructor kit looks AMAZING!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
