Burnsi
02.22.2009, 11:51 AM
hmm, is anybody here who can check the cc against a medusa 70 or 80 with 1600kv?
02.22.2009, 03:21 PM
Check for what? The CC motor is a good 4-5 motor. A 1600kv medusa 70mm motor on 6s should have similar performance to the ccneu if you run it on 4s. 5s on the ccneu will make more "power" due to higherr motor rpm (if you gear down for the same speeds).
A medusa 80mm will have more torque than the 70 or ccneu, and is a better choice for a heavier vehicle. So it will handle more load and put out more power.
IMO, the 80mm is the best bet for a lst. The 70 and 1515 are a bit small. They are good for lighter trucks such as emaxx and erevo. Even a savage is lighter than a lst. I generally go for a longer motor as they will run cooler, and my battery choices can keep up with the increased demands. I am going to a 1521 for the lst I have, just cause I want 45+ mph speeds.
