Go Back   RC-Monster Forums > Support Forums > Team Tekin
Semi Pro
Semi Pro's Avatar
02.26.2009, 07:59 PM
Originally Posted by teamtekin View Post
Thanks for the opportunity to lay it out. In short we make great products with personal commitment, offer them at a fair price and support them.
Currently we truly do stand alone with the only high power system with 40mm multipole motors that are sensored and run sensorless for perfect response in any situation. In addition we really have done a good job with features, size and performance. You can adjust almost everything right on the unit with few quick button pushes and the hotwire lets you really dial it in.
Like all of our products no compromises have been made right down to the dual contact, self cleaning power switch and servo plug that is best we could find for fit and signal quality. We use gold plated solder posts for tight installs and low losses. We have a small PC for a micro that gives us the ability to update and improve the unit ongoing. We buy leading edge components and use super heavy copper power boards. The fan is quick and easy to replace since we know they will break at times and the housing is made of tough Polycarbonate instead of the typical ABS. The Rx8 is the smallest footprint, handles as much power as the batteries can deliver with control and feel.
The Rx8 has a ton of user feedback with the 7 leds to show error codes and help diagnose issues. We show you if there is no radio signal, or we do not like the signal, or it is not changing like when a spectrum receiver will hand us the default neutral when it is not communicating with the transmitter. We have a real time temp monitor so you can look down and quickly know your internal temps and drive off again. We even have a sensor checker that allows you to see if all the sensors are working correctly. The top 3 leds light up with the sensors and you can turn the motors slowly with your fingers and watch them tick away.
It is also backed by Tekin, which means support by people that are as passionate about the hobby as you are. In the near future we are confident it will speak for itself in terms of performance, reliability and overall satisfaction.
Buy Idaho!
what will the warrenty be on the rx8 system?
will teken still warrenty the system if we are useing it with nue 1509 motors?
