What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.27.2009, 01:34 AM
Wow. It's been a while. Oh wait- we're in a recession and I have no liquid assets! That's why!
Anyhow, I ordered up some 12"x24"x0.08" (2mm) 7075-T6 aluminum plate a couple weeks ago. The other day I got around to cutting it up. Here's what it looks like now:
I also ordered a 12"x48"x0.025" piece of polycarbonate to make the sides and the internal support structures. It came today, so hopefully next week I will have time to cut it up a bit. I'm going for the "speed wedge" look, with a twist- I'm going to design a venturi into the top so that it will create a vacuum inside the body and (hopefully) help stick the car to the road.
02.27.2009, 02:06 AM
Hmm, sounds like the pike's peak racers that have the huge tunnels that produce downforce...
I found that Lola style bodies work like a charm at speed. Problem is none are made that are wide enough to work on a gtp...
What's_nitro?
02.27.2009, 02:11 AM
I like those Lola's too, for 1/10 TCs. IF they made one for 1/8 cars, it would be too high in the back for real speed runs. Too much rear downforce. That's flip territory. I suppose you could chop down the rear wedge a bit. Maybe replace it with a normal wing.
