03.02.2009, 11:00 AM
Did you guys recalibrate your radios to the esc after the update? Zero all of your settings on the throttle channel, recalibrate and see if that helps...
samwong
03.02.2009, 11:04 AM
Let me try it now....
if it is the case... then Losi...... ah....
samwong
03.02.2009, 12:00 PM
have another effort.... but the result is...
after reinstall Version 2 software, and import F010120 , setup/Calibration to Transmitter, i.e. Full Throttle to Green light solid, Full Brake to Red Light solid, Neutral Position, but blue light only flash a while then no light anymore...
Test again... forward ->ok , brake -> , reverse -> heavy brake follows after each reverse, which shake the motor and whole transmission.......This is a big problem.....
How Losi design the software???? Totally a mess.........
