samwong
03.02.2009, 11:04 AM
Did you guys recalibrate your radios to the esc after the update? Zero all of your settings on the throttle channel, recalibrate and see if that helps...
Let me try it now....
if it is the case... then Losi...... ah....
samwong
03.02.2009, 12:00 PM
have another effort.... but the result is...
after reinstall Version 2 software, and import F010120 , setup/Calibration to Transmitter, i.e. Full Throttle to Green light solid, Full Brake to Red Light solid, Neutral Position, but blue light only flash a while then no light anymore...
Test again... forward ->ok , brake -> , reverse -> heavy brake follows after each reverse, which shake the motor and whole transmission.......This is a big problem.....
How Losi design the software???? Totally a mess.........
