Traxxas Mutt
Tarill the Mad
Traxxas Mutt - 03.03.2009, 02:01 PM
First I want to thank Mike for the fast response to get my acct active, because I'm new to the forum after lurking for a month or so. I wasn't sure where to post this but I was wondering if I'll have any problems using parts from an e-revo, summit, and an e-maxx. Most of the chassis and suspension is summit or revo based and will have a e-maxx transmission from the 3905 model. The main reason I'm going with the summit/revo chassis mix is because I wanted to try out the locking diffs but don't want to spend 600+ on a summit for just the diffs. Wanted to use the emaxx transmission so that I can use it's plate for a future upgrade to dual brushless and it looks to be the same as the e-revo. I've got the parts ordered and on the way so no pictures yet. I'm dubbing this my Project Traxxas Mutt. I was just wondering if anyone might have some experience or advice on mixing the parts or info on the summit diffs. Also what body mounts I should use so I can put a gravedigger or monstermutt style body on it. I'm just getting back into rc after finding an old car and parts in a box and now have 6 or 7 projects in mind, some of them already in the works. Thanks for any and all input.
Andrew32
03.06.2009, 06:33 PM
unfortunantly....i tihnk your gonna be the teacher and we the students on this one... i believe your gonna have to make a few adaptors to ake everything fit nicely, but im with you...$600 for a summit is
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.06.2009, 08:22 PM
Welcome to the Monster!
I was under the impression that the Summit/Revo used a very similar chassis..? It's not hard to modify a Revo chassis to accept the Maxx tranny (many members of this forum have done it).
It sounds like an interesting hybrid. I demand pictures the second you get parts in your hands.
Tarill the Mad
04.19.2009, 05:42 PM
Some pictures of parts for my project. Pix of the summit chassis, front and rear assemblies are mix of summit and revo parts, and maxx tranny. The only difference I have bee able to find between the revo and summit chassis is the small notch on the ends that let the locker levers hook to the differentials.
ID:	6876   Click image for larger version
ID:	6877   Click image for larger version
Tarill the Mad
04.19.2009, 05:53 PM
Pixs of the differentials and locking servos, all the parts I have for it assembled. Now just waiting on drive shafts, drive hubs, steering servos, shocks, and rx/tx. Have to decide on what rim/tire combo and body I want and finally the motor/s and esc that will power this monster. Last 2 pixs are of the new 775 and esc that I rigged to go in a really old truck I had laying around just to test the motor out. The torque it puts out is insane. Wants to pop a wheelie with hardly any throttle applied. Once it quits raining here and I get a basher body to help protect it I'll break the motor in a bit more.
ID:	6880   Click image for larger version
ID:	6881   Click image for larger version
Tarill the Mad
04.19.2009, 07:41 PM
I was going to try to run 2 of the new 775 titans. The size of it makes it hard to fit on the tranny like the 550's sit on a emaxx. Thinking of trying to make a mounting plate that flips them to face the opposite direction. At least untill I can afford a dual BL setup. I'd be happy for any input anyone has for me.
crazyjr
crazyjr's Avatar
04.20.2009, 10:38 AM
Why not just one? they seem strong enough, and les stress on the EVX. you could turn the transmission around backwards and use a erevo/summit motor mount setup
What's_nitro?
04.19.2009, 05:48 PM
Looking good. What do you have in mind for a power system?
What's_nitro?
04.19.2009, 10:40 PM
Kershaw Designs makes a mount for using dual 750 motors; you could try that out. Or call/email Mike and ask him to make one for you.
Tarill the Mad
04.19.2009, 11:41 PM
Thank you for that. I'll have to check them out and see what they got. Do you know much about their products and service?
scarletboa
scarletboa's Avatar
04.20.2009, 03:21 AM
he's making a custom motor mount for my savage right now. the motor i am going to use is to big to go where a normal 36mm motor would go.
Finnster
KillaHurtz
Finnster's Avatar
04.20.2009, 05:04 PM
^+2 on that.
Why the dual BL as well? Its not really needed at all. A single BL motor can put out more power than God can handle, so two is really unneeded and overly complicated.
Some have done that V-twin and other dual BL rigs, but overall they are a silly design and far more hassle and expense than they are worth.
04.20.2009, 05:16 PM
^ +3.
Like was said, dual motor/ESC just complicates things, and increases the chances for problems should an ESC or motor go bad (like if a motor demags a little). I can't think of any instance where a single larger motor would not be preferable to a dual setup. Unless it's for show, because it does look cool.
BlackedOutREVO
04.20.2009, 07:17 PM
^ +3.
+ 4
Guess i will join the party
Single BL, less weight, less to go wrong. Nuff said. BUT to each his own...
Tarill the Mad
04.21.2009, 12:51 AM
WOW! I stirred up a hornets nest. ok maybe I'll drop the dual ideas. Is the EVX able to handle a lipo? I am just getting back into rc so lipo and brushless are still unknowns to me but you guys here have been helping to edumacate me.
