Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
03.03.2009, 10:44 PM
Wow, it launched out! !!!
Metallover
RC-Monster Spudgunner
Metallover's Avatar
03.03.2009, 10:51 PM
I wanna see pics of everything.
mkrusedc
NeuMaxx
mkrusedc's Avatar
03.04.2009, 12:10 AM
Something Went in the transmission.. was running out in the snow and watched a small fragment of something go flying out of the truck then had no power to the wheels. upon further inspection there is a gauge mark on the top of the transmission where a pin(i think) came out the top.. And now the top gear shaft and slipper can slide in and out of the transmission about 1/2 inch. I tried the truck out in 1st gear to diagnose, and found nothing, but in second the truck runs fine until the top shaft jumps out.. this leads me to beleive that the 1st gear roll pin came out..
What do you guys think.
Can i tell you that it is a PITA to get the trans out of an emax..
Sounds like the input shaft roll pin. Use a piece of an allen head wrench or a steel drill bit cut down to fit. That with steel idlers and your tranny should be rock solid.
brushlessboy16
brushlessboy16's Avatar
03.04.2009, 07:52 AM
Yeah, i replaced it with an allen wrench end. The idlers have 0 wear as far as i can see. :)
Have to send the pics from my phone. they will be up later
brushlessboy16
03.04.2009, 07:54 AM
Yep, roll pin has left the building!
Its not that hard to remove an emaxx tranny really, only 8 screws...
I have pita MIP cvd's. strong units- but arent as easy to work with as the sliders
brushlessboy16
03.04.2009, 08:01 AM
Finnster
KillaHurtz
Finnster's Avatar
03.04.2009, 11:15 AM
Nice to see the 8XL is back to destroying maxx trannies :)
It did even kill an allen wrench fix once. Then I drilled out the hole a bit and used a bigger pin. G/L
brushlessboy16
03.04.2009, 12:33 PM
I hope this one will stay together, thanks for the motor finnster :)
brushlessboy16
03.04.2009, 08:08 PM
I think i blew the rear diff, tell me what you think
Metallover
Metallover's Avatar
03.04.2009, 08:12 PM
Hell, the diff will go out in any car if you put it on carpet and "test the diff"
I would run it until it doesn't run no more. Then you know it's broke.
brushlessboy16
03.04.2009, 08:26 PM
now its ticking. and its reallly annoying.. great, now i gotta buy diffs :)
Krawlin
Got brushless?
Krawlin's Avatar
03.04.2009, 11:55 PM
Glad to see my MM found a good new home! Also glad to know that it doesn't shut off and on with your setup like it always did in my Maxx.
BTW, do the tranny flip, lock it in 2nd, and mount the ESC in the back, its a much better layout IMO.
Monster GT Conversion
mkrusedc
NeuMaxx
mkrusedc's Avatar
03.05.2009, 12:07 AM
FLM hybrid bulks with Hot bodies 1/8 diffs ahve been rock solid for me.
brushlessboy16
03.05.2009, 07:27 AM
sounds expensive
George16
Supermaxx
George16's Avatar
03.05.2009, 08:26 AM
Search for its-me's thread about using a lst diff on your maxx bulkhead. I think that's the cheapest alternative.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Tags
brushed, kick ass maxx 2, mmm
