jahno30
03.04.2009, 02:09 PM
Originally Posted by Countryhick View Post
I think you will have good speed with that combo of motor and battery. Where were you thinking of mounting the battery? Most 1/8th chassis have a clearance of 30mm between the top and bottom decks (yours maybe different).
Keep us updated with some pics as you progress.
P.S.
For those interested, I took some new video footage of my car last weekend. I have to edit up a clip as I used 2 cameras at the one time.
I was thinking about using some 6mm carbonfiber, plastic, or plaxiglass flat spacers under the 5xscrews that hold the radio plate to give the additional height required and use plastic spacers on the chassis to possition the battery... I was even considering going with the 6S 4000 http://www.hobbycity.com/hobbycity/s...idproduct=7657 and switch the steering servo to lay on top of the radio tray to get the battery in but using a different kv motor.. My thoughts were the 2650kv combo maybe the better option if I could keep the weight low enough, but not sure if the run time will be any good........what do you think will work out better?
