slimthelineman
slimthelineman's Avatar
03.04.2009, 07:45 PM
hey patrick, any 6s batteries come to mind for racing a rc8/1512 3D? currently running some neu 3200 xp's but the tech @ castle said they were a little too small.
Pdelcast
Pdelcast's Avatar
03.04.2009, 07:52 PM
And for those who might be interested, here is a panel of 20 MMM boards, with a single X-OUT circuit (bad circuit detected by test machines, and left unpopulated.)
Patrick del Castillo
President, Principle Engineer
e-mike
e-mike's Avatar
03.04.2009, 07:54 PM
thanks for the clarification Pdelcast!!!!!like ive said so many time the mmm is a powerful esc
D8t on juice!!
e-mike
e-mike's Avatar
03.04.2009, 07:57 PM
so there not a big difference(in fet's number) between the mamba max and the mmm... why the monster it is a lot more powerfull???
D8t on juice!!
Pdelcast
Pdelcast's Avatar
03.04.2009, 08:03 PM
The number of FETs dictate the amount of current (AMPS) that the controller can handle. The Mamba Max and the Monster Max are similar in peak amp handling capability, but because the Monster has a large heat sink and fan and more FETs, it's continuous amp capability is a little higher.
The Monster is also capable of double the voltage of the Mamba Max, which doubles the power handling capability.
ALSO, the FETs are better today than when we designed the Mamba Max -- so the current version of the Mamba Max can handle more power than the original. (the number of FETs is a bit of an overkill on the Mamba Max.)
e-mike
e-mike's Avatar
03.04.2009, 08:11 PM
wow you want explanation....youve got itso the actual mamba max can handle more current...than the hold version....good i will try it on 6 cell lipo(joke)
thanks again.Pdelcast..
dont forget guy'sjust use the right pinion and spur and see what happen
D8t on juice!!
sikeston34m
sikeston34m's Avatar
Wow Patrick!
That's some really neat stuff you're doing there. I think I could just get lost on your side of the street.
I want to learn more, that's why I ask so many questions sometimes.
johnrobholmes
johnrobholmes's Avatar
03.04.2009, 08:05 PM
The MMM build is almost fully automated then eh? Pick and place for the bullets? I would guess you put on the heatsink and case by hand.
---JRH---
Pdelcast
Pdelcast's Avatar
03.04.2009, 08:08 PM
Actually, the bullets are placed by hand before reflow. Wish we could place them by machine, but they are through-hole and a tight fit (for current handling.) (It takes a steady hand to place them...)
Power wires are soldered by hand, cases, labels, heat sinks, fans, etc. are all placed and assembled by hand.
Pdelcast
Pdelcast's Avatar
We use a lot of different batteries here with good luck, but I think everything we have used has been in the 5500mah or larger range. I'll ask Mike to recommend something for you.
Thanx!
