e-mike
e-mike's Avatar
03.04.2009, 07:57 PM
so there not a big difference(in fet's number) between the mamba max and the mmm... why the monster it is a lot more powerfull???
D8t on juice!!
Pdelcast
Pdelcast's Avatar
03.04.2009, 08:03 PM
The number of FETs dictate the amount of current (AMPS) that the controller can handle. The Mamba Max and the Monster Max are similar in peak amp handling capability, but because the Monster has a large heat sink and fan and more FETs, it's continuous amp capability is a little higher.
The Monster is also capable of double the voltage of the Mamba Max, which doubles the power handling capability.
ALSO, the FETs are better today than when we designed the Mamba Max -- so the current version of the Mamba Max can handle more power than the original. (the number of FETs is a bit of an overkill on the Mamba Max.)
Patrick del Castillo
President, Principle Engineer
e-mike
e-mike's Avatar
03.04.2009, 08:11 PM
wow you want explanation....youve got itso the actual mamba max can handle more current...than the hold version....good i will try it on 6 cell lipo(joke)
thanks again.Pdelcast..
dont forget guy'sjust use the right pinion and spur and see what happen
D8t on juice!!
