Metallover
RC-Monster Spudgunner
Metallover's Avatar
03.04.2009, 08:09 PM
I would guess if you put some screen or mesh of some sort over all the holes then that should protect the motor enough. I don't have any cover on mine and I don't plan on putting any cover on. With the motor spinning the rock would have a tough time getting in there. Besides, if the motor does get ruined, it would be an excuse to get a castle outrunner. I would definately put mesh on that. I doubt warrenty would cover that.
Pdelcast
Pdelcast's Avatar
03.04.2009, 08:10 PM
Like you really need an excuse.
Patrick del Castillo
President, Principle Engineer
sikeston34m
sikeston34m's Avatar
03.04.2009, 08:24 PM
Do these motors have a 5mm shaft and 25mm bolt spacing?
I've ran alot of different "land vehicle" outrunner setups and I've never had a motor fail because of debris.
With the E maxx and the E Revo, the motor sits toward the front of the platform and in the middle. It seems to be pretty protected there from UFO's.
I can see how some setups would be more at risk. Such as being low, in the back and center. That's like dirt central.
Pdelcast
Pdelcast's Avatar
03.04.2009, 08:29 PM
The 30mm and 34mm motors do have 5mm shaft and 25mm bolt spacing. The larger motors have 6mm or 8mm shafts, and the smaller motors (22mm) have 3.2mm shaft.
One of the issues with outrunners is that the magnets are hanging way out -- they tend to collect stuff we would never think they would pick up... there are literally billions of little iron filings in streets and alleys everywhere (shed from cars...)
himalaya
himalaya's Avatar
03.05.2009, 12:56 AM
That's why your outrunner still survives, I toasted mine(Align 600L) in my 8ight-T after I covered all the vent holes to keep the inside clean. Outrunners' coil seems having really hard time getting heat out.--- they fit open air use only.
....What a Blue Sky....
