auto2
03.05.2009, 08:11 AM
if you lock the ctr diff it will flip over backwards. also it will push going into a turn. have less steering. if yu just bash it might not matter. cant hurt to experiment with oils.
808??
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
808?? - 03.05.2009, 09:15 AM
Does the 808 use the same diffs as the HPI lightning setup? If so you can put a locker (http://www3.towerhobbies.com/cgi-bin...3&I=LXNWS7&P=K) in the diff if you wish.
SUPERMAXX YOUR LIFE.
