Joey
The Big Cheese
Joey's Avatar
03.06.2009, 04:44 PM
Yeah Ive talked to Bithed quite a bit about it on esavage.com... hes a great help. Lots of great material here to get ideas from. Did you find a way to mount your 2 speed tranny lower in the 21 chassis or did you just throw it in the stock position?
Joey
The Big Cheese
Joey's Avatar
03.07.2009, 12:14 AM
My attention was brought to this speed/gearing calculator and it is amazing. I used it to get the following numbers...
http://www.scriptasylum.com/rc_speed/_top_speed.html
For savage diffs, center diff, 48T spur, 14T pinion, feigao 8XL (2084 kv), 16.8V nimh (I know.. I know...), and bow tie MTR tires I get:
-- Total Motor Speed: 35011 RPM
-- Theoretical Maximum Vehicle Speed: 51.89 MPH
With 9XL (1853 kv) it is:
-- Total Motor Speed: 31130 RPM
-- Theoretical Maximum Vehicle Speed: 46.14 MPH
If I switch it to the e-savage tranny the speeds drop by over 50%, so higher KV motors and gearing changes would be required for that. Im sure the actual speeds would probably drop by about 10% due to losses, so its probably more like 47 mph and 41.5 mph. I would be more than happy with either!
03.07.2009, 12:25 AM
Cool conversion sofar. My banana is banana is better than your banana though.
03.07.2009, 12:27 AM
I typed "is banana" twice!
Joey
The Big Cheese
Joey's Avatar
03.07.2009, 12:38 AM
Hahah BANANA REPRESENT!
