Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Savy build
tklemin
Savy build - 03.06.2009, 09:15 PM
Thanks for the props. I was trying to make the baddest truck Ive ever owned. The motor plate is from KD. It just has a double mount for brushed motors I guess. The weight distribution probably could be a little better, But the batts still sit pretty low in the truck, and I still have the hump pack in the box that evens out a little. That was part of the reason I used the XL chassis. I figured the the longer chassis would even out the weight of the more rear weight of the batts. I just like the look of the batts tucked in, and it might ad a little more clearance under the truck and protect the lipos also. It drives great (not to flippy). As with most 6s trucks it takes a more dialed in throttle control than with gas. It took a few charges to learn to drive again. With my gearing It will still do standing back flips, but its not to bad after half speed.
ID:	6528   Click image for larger version
ID:	6529   Click image for larger version
Janezki
Avid Gear Crusher
Janezki's Avatar
03.08.2009, 05:49 AM
My project was halted for a while because of my overwhelming work schedule, but now when I've had few days' vacation I've managed to do quite a lot - so here's what has happened so far:
- Kershaw direct drive reversed for the sake of weight balance and to get the lipos between the TVP's
(gearbox needed quite a lot of trial & error shimming before I got it running smoothly)
- stock radio box removed and replaced with Fastlane servo plate
- broken steering servo & front diff fixed (these broke while my last bash session)
I had one KB45-10L 1800kv motor lying around, so I really wanted to give it a try and see how it runs. The kv-rating is a bit high for 6S but hey, just for the heck of it...
Here's a few photos from yesterday - I was in a hurry to get my truck into running condition so I had to use few "temporary" solutions to get all in place (mainly the esc & receiver).
(click for big pic)
The KB45-10L is quite a power plant - even though there was no grip at all on snow I managed to pull over 2000 watts from it with 6S 5000mAh 15C Zippys according to Eagle Tree.
Here's some chart data:
(there's some glitch there with +8600W & +80V peak values :))
Gearing used was 20t pinion, 47t spur.
I measured 60°C (140°F) from the motor endbell and the ambient temperature was -1°C (30°F).
Summer temperatures may be too much for KB45, but I'm planning to use a different motor then.
The car handled pretty well - although my driving was mainly on flat surface with few minor jumps from snow bank, I'm quite pleased with the weight balance.
Only problem I had was with the pinion which wasn't hardened. It was simply ruined just with one set of 5000mAh batteries...
Next step will most likely be upgrading the diffs.
Savage03
03.08.2009, 12:22 PM
Looks good! So the direct drive did ok? Might be time for some meatier tires
Janezki
Avid Gear Crusher
Janezki's Avatar
03.08.2009, 02:44 PM
Yes, direct drive does perform well. I'm waiting for the snow to melt for some serious traction...
BitHed
03.08.2009, 09:38 PM
...Janezki...Agrre with you on the direct drive / center diff...MUCH better feel...
...how do you like those tires? How do THEY like the power you are ruinning through them? Do they balloon much?
Janezki
Avid Gear Crusher
Janezki's Avatar
03.09.2009, 10:43 AM
Stock tires are decent, even though they balloon like crazy with full throttle.
I haven't been able to run my truck on grippy surface at all, hopefully the snow melts in about months time.
I was considering ProLine Badlands, but they are so "small" - I wish there was an easy way to put Baja wheels & tyres on Savage.
Savage03
03.09.2009, 10:48 AM
If you want bigger next best thing to baja size is LST tires what I use and love em, do very well on all surfaces.
