Jason
03.08.2009, 03:10 PM
I have just realized my e-maxx is a 0.8 mod spur gear and the only pinion I have is only 1.0 mod do it can work together without any trouble ?
Metallover
RC-Monster Spudgunner
Metallover's Avatar
03.08.2009, 03:19 PM
nope
Jason
03.08.2009, 03:32 PM
ok! I have see this one should work on my maxx :
http://www3.towerhobbies.com/cgi-bin...?&I=LXFUA5&P=7
it is mod1 right ?
03.08.2009, 04:57 PM
it is mod1 right ?
It will work with a few mods. Open the center hole up with a reamer to match the slipper bearing. and you will also have to open up 3 of te smaller holes to fit over the slipper screw vosses so that the spur will fit flat on the slipper. Really easy, will take you 1-2 minutes, max.
Jason
03.08.2009, 04:58 PM
ok cool and do I can match a 17t pinion on it without any trouble right ? since the stock e-maxx spur was 68t and this one 52t ( mod1 )
03.08.2009, 05:00 PM
It should fit, as the 52t supr is larger in diameter than a 52t 32p spur would be. Your gearing will be higher, so the truck will be faster.
Jason
03.08.2009, 06:00 PM
ok nice, anyone know other mod 1 spur gear from other rc brands that direct fit the e-maxx 3905 ?
