BitHed
03.08.2009, 10:24 PM
...a wet weekend, a toothbrush and a drill and its starts looking FACTORY!!!
BitHed
03.08.2009, 10:25 PM
The upper arm brackets got de-nuded and went in very well after fabbing some brackets and other little doo-dahs...
...Here is the front...
...and the rear...I didnt put in the 5mm spacers for the top screw to the bulkhead...in fact i left out that screw completely until i can get some more 4x50's...
BitHed
03.08.2009, 10:26 PM
...i was using a modded e-sav motorplate on the CD but as a shout out to the boys at Medusa I modded a Tamiya CR-01 motorplate, from 3Racing, which matched the blue and was able to be keyed to the diff carrier with 4 screws instead of 2...I was all out out blue nuts so i chucked on some wanky titanium ones I had lying around...
...In the final 2 shots BOTH motor plates are on...Just though I would leave on the purkle one just in case...
...sorry my album is being a prick and all these shots are sideways...
...From THIS...
...To THIS...
Savage03
03.09.2009, 10:27 AM
Very nice rig! Can you maybe go into some detail on mounting a hellfire diff? SOme shots of it installed? Debating on this mod or the kershaw unit, right now im using a stock 2sp locked tranny but wish HPI would design a better working slipper cause the wheelies are a pain.
BitHed
03.10.2009, 09:52 PM
...getting sick of JUST pictures yet? Well i sure am...Getting closer to video though as the truck is now pretty much dialed in...Just a few little things to do to it but its 100% running...
...4.4 kg RTR...medusa 36-60 2200...Kyosho 46 spur / nameless 16 pinion (Mod 1)...HPI DirtBonz on Kyosho 10 spokes...HF shox, center diff, towers and wing / wing mount...4S 4900 lipo...
BitHed
03.10.2009, 09:54 PM
...look at how low and slick this thing is...Drives GREAT!!
...If you CAN, get the upper arm brackets for the Savage...TOTALLY different ride and quite possibly the BIGGEST handling mod you can do...Cheap too...
...Last night out in the dark and the cold on half-power packs it drove great...Almost zero wheelies...A little mod to the front prevented pizza-cutters too...I did wheelie it once, on command, and it went for quite a few meters on the wing :D
...Steering was VERY touchy due to the lowered roll center and had to turn it down...I was worried the wider front hexs would affect steering circle but it didnt at all...
...The new battery boxes are FANTASTIC and dont miss a beat...Got rid of the awful velcro too...
...it was friggin cold but not a peep from the batteries, motor or MMM...Schweet...Gearing needs to go with a 14 pinion too, just to slow it down a little and make it slightly more bashable...
...I will most likely pass on the alloy body and go straight to the new Proline Streamline body...its the first time EVER that i have seen the need for a low-profile, aerodynamic body on an RC...but as it will hardly traction roll now it should last a while...
...The bumpers still annoy me and I havent come up with a decent solution yet...
...New chassis should be here soona nd then its just down to sinking all the screws and mounting it all up again...
