hardmankam
03.09.2009, 10:27 AM
yeah, i read about the Kyosho plastic gear. in fact, i have 1 right now, but because i will run the car in a gravel field, the plastic gear will be chewed up in no time.
i still find the outrunner option a very 'cool' setting, since it is direct drive which provides lots of torque and is ultra-quiet.
BL-Power
BL-Power's Avatar
03.09.2009, 05:17 PM
You are completly right, it's smooth, light-weight, quiet and powerful but not very durable under real offroad conditions. It's not to expensive, if you've already got a ESC and a battery you have to spend around 50$ for the motor and some small parts like cups, dogbones and a motor mount. If it works stable under the conditions of your driving spot, you can keep and have a lot of fun. If you've got problems with it, you don't have lost too much and you can use your inrunner again.
The Kyosho gear is quite durable, i don't think it will be damaged.
 Send a message via ICQ to BL-Power
