Cartwheels
03.09.2009, 10:46 PM
Originally Posted by Shark413 View Post
You have to be careful regarding the bearings. If they blow out the race the rotor can become loose enough to hit the inner coils which would be bad news. You can grab the end of the shaft/pinion and try to move it, when the bearings wear out you will feel movement, a new bearing or one in good shape should have zero movement.
in and out or side to side?
Shark413
Shark413's Avatar
03.10.2009, 02:11 PM
That would be side to side, any movement in this direction could mean the actual balls or races are wearing out. Normally what happens is the bearing gets dry (no oil/grease) or dirty. Then the friction and heat cause the cages (these hold the balls in the proper position) to fail, which leads to major bearing failure. With In and out movement there is a little more play, even if there is movement in this direction when the motor energizes it will self align (center the rotor betwween the coils). Of course you don't want excessive movement here either, but a little is ok.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Shark413
Shark413's Avatar
03.10.2009, 02:27 PM
Here is a shot of a motor showing the spacers/shims that are used to center the rotor. Below that is a blown out bearing, where the cage failed. Another thing you need to watch is when installing bearings always try to push them in by there outer race. Some people just slip them over the rotor shaft and hammer them in, what this does is it puts pressure on the inner race, which then transfers that to the balls. This can leave microscopic dents, which will cause premature wear. I made a simple aluminum tool out of some scrap, that has a small cone shape piece in the middle that the center hole of the bearing rides in (this centers the bearing), then it is dished out slightly and only the outer part contacts the bearing (the outer race). This way I can push in the bearings with pressure only on the outer race.
losi b
03.10.2009, 10:12 PM
Thanks for all of the input. Just to follow up, Neu recieved my 1512 on Tuesday afternoon and they put it in the mail back to me Wednesday afternoon. I also ordered a tube of 10 replacement bearings. The charges where $60 total. ($30 for the bearings/ $30 for repair and shipping) I would say that's pretty good all around. As far as how often the bearings need to be changed, they recommend replacement as soon as the bearings make any noise what so ever. I will start removing my motor every 5 packs from here on out.
Thanks again for your input.
Brian
Shark413
Shark413's Avatar
03.11.2009, 01:37 AM
Here is the tool I was talking about.
Aluminum rod with a small cone on the end.
The bearing fits over the center nub and that helps center the bearing.
The green area is lower than the outer edge, so only the outer edge contacts the bearing (the tool only presses on the outer race).
