03.24.2009, 06:41 PM
What radio are you using? Sounds like you may need to zero everything to do with the throttle channel and recalibrate the radio to the esc. I am not familiar with tekin products, but if it works one way and not the other you may have a controller issue. Do you have the reverse % set very low?
whitrzac
Can't catch this...
whitrzac's Avatar
03.24.2009, 07:38 PM
Would you mind posting a picture of your settings? If it isn't your settings, the only thing that comes to mind would be binding. Push the thing in reverse and see if it rolls as smoothly as forward. You could have a drivetrain problem.
its a JR XS3(75mhz fm), it has the same functions/adjustments as the spektrum DX3 without the whole spektrum thingy. I'm 100% positive that the setings on the controler are right...
the drivetrane isn't binding at all, so thats not it.
EDIT: I found the problem, the CC bec is set at 5.1v from the factory.I hooked up the esc without the external bec and problem solved...
anyone have a castle link I can barrow?
Metallover
RC-Monster Spudgunner
Metallover's Avatar
03.24.2009, 09:36 PM
How is your bec causing the problem? If the esc works witout the bec then I guess it doesn't matter.... 5.1v is perfectly acceptable.
whitrzac
Can't catch this...
whitrzac's Avatar
03.24.2009, 09:53 PM
IDK why, but when I use the BEC thats built in with the tekin it works fine, and when I hook up the CC bec it cogs...
Metallover
Metallover's Avatar
03.24.2009, 09:58 PM
So I need to review. Can you post any pics? I think you're using a tekin sensored controller with a Neu motor. Is the sensored esc and the sensorless motor the source of the problem?
img]www.postpics.com/likethis[/img]
whitrzac
Can't catch this...
whitrzac's Avatar
03.24.2009, 10:21 PM
nope, the esc is sensor/sensorless/brushed/brushless
what do you want pics of?? I'll get them tomarow
whitrzac
Can't catch this...
whitrzac's Avatar
03.25.2009, 02:45 PM
I bought it because I could get one cheaper than the retail price(ALOT cheaper) knowing what I know now, I would paid full price for one too.
when the RX8 becomes more avalable I'm going to sell the RS and the neu and buy one of the combos...
BTW there non warrenty repair/replacement> than castle's
besides the RS goes back and forth between my mod class slash and the buggy
I still need to know what you want pics of...
Metallover
Metallover's Avatar
03.25.2009, 06:26 PM
I just need pics of your setup... The rs pro is a sensored esc mainly, build for racers. I am thinking since reverse isn't allowed in most racing that the esc might not have it? I really don't know what else it could be.
whitrzac
Can't catch this...
whitrzac's Avatar
03.25.2009, 08:09 PM
it has reverse, I got yelled at for using it when a marshal didn't see my truck...
I know its the CC bec now...
whitrzac
Can't catch this...
whitrzac's Avatar
03.25.2009, 10:37 PM
http://s272.photobucket.com/albums/j...zac/hyper%207/
the esc isn't in its final location, nor is the CC bec. a few pics of the "damage" and this is the first, and last time that my tempo has ever been photographed
I'm going to get a T maxx RX box to put everything in...
Metallover
Metallover's Avatar
03.26.2009, 08:00 AM
Which one is it? Just the Hyper 7 mount?
It's more helpful to post your pics in the thread so nobody has to navigate around to find it. Just a thought.
edit- I realized your pics are too big. When you upload them limit the file size. Then post them directly in the post. With the pictures you alread have, this is how I would do it.
whitrzac
Can't catch this...
whitrzac's Avatar
03.26.2009, 08:31 AM
I'll get to resizing them sometime today.
its a hyper 7/8/st mount, as far as I know, brian would know more...
and to conferm your observations, yes that is duct tape, I ran out of heatshrink...
I won an auction on ebay that had a 2 speed set for the H7, would it be worth it to install it? the
buggy probably isn't going to see any track time... anyone know the stock tooth counts on it?
whitrzac
Can't catch this...
whitrzac's Avatar
03.26.2009, 04:49 PM
i guess the 2 speed is out of the question now, it needs mecanical brakes.
03.26.2009, 06:06 PM
True, you will have to run mech brakes...
whitrzac
Can't catch this...
whitrzac's Avatar
03.26.2009, 10:14 PM
what about this slipperential thing majig? how much $$??
