03.11.2009, 12:27 AM
Originally Posted by whitrzac View Post
those were the first ones I looked at and I almost _____ my pants....
They are pricey and they are way too heavy. I would se the novak trays, or maybe cut down an old emaxx chassis, I did that a few times to fit my hardcase trakpower lipos.
whitrzac
Can't catch this...
whitrzac's Avatar
03.11.2009, 08:10 AM
I never thaught about the e-maxx chassis....
the way its looking I'll be going with the novak trays
are there any hints you can give to make my converson less painfull?
what would be the recomended gearing?
also, I'v seen people runing a kyosho plastic spur, whats the advantage of doing that???
03.11.2009, 10:44 AM
The conversion is pretty straight-forward... Just keep an eye on your signal wires, and try to keep them as neat as possible.
I like the plastic spurs as they are much quiter. And if you really stuff it hard, or land very poorly the plastic will give a little, or break, saving the motor... I would rather replace a 4 dollar spur than a motor. Mainly I use the due to the noise...
Recommended gearing is going to be difficult. I would almost suggest going to the 5.5 or 6.5 novak. The 4.5 is a high kv, and it may be difficult to get a small enough pinion to physically fit.
Your motor mount link does not work, what does it look like? How does it position the motor?
