Jeremy1976
03.12.2009, 08:26 PM
Just looked at it again and it should work. It is not completely lined up but the mesh is good.
Unsullied_Spy
Unsullied_Spy's Avatar
03.14.2009, 06:20 AM
That's good enough for now. Seriously though, go with Rootar's advice and get the nastiest gears you can get. 32p will be fine and you can get 32p pinions in the 1/8th inch shaft and it will be leaps-and-bounds stronger than the 48p gears you're using now. With one of Mike's bore reducers you could run a Mod1 gear on there (should have gotten a 5mm shaft from the start but you live and learn) and a Revo spur gear. If you strip a Revo spur gear in an ER you've got either mesh or bearing problems.
Jeremy1976
03.14.2009, 09:20 AM
Yes that is the plan! I got some 32 pitch gears coming and the bore reducer. Thanks for the reply.
