dmeylman
03.12.2009, 10:58 PM
Off topic...but I have a question about badland tires. Looking on top, Is the other side of the tire suppose to be a little flat than the other? And also, I have maximizer beadlock 0 offset, do I need to use shim on both sides? The manual states that if using proline tires...thanks...
rhylsadar
rhylsadar's Avatar
03.13.2009, 04:06 AM
hi
i did it exactly the same way.
however my longterm experience is not that good with taped tires. once some water or dirt gets into the tires (which is impossible to avoid imo) the tape can get loose and then things mess up rather quickly.
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
