rchippie
rchippie's Avatar
03.13.2009, 10:15 AM
Sean you told me yesterday linc was taking to long getting your packs done, & you could have done it faster yourself .
REAL MEN RUN BRUSHLESS
03.13.2009, 10:26 AM
Originally Posted by johnrobholmes View Post
Good read. Subscribed so I can keep an eye on what you find. PolyQuest is indeed an Enerland house brand, btw. And I heard they have China factories now too. With a123 in control we may see a lot of action from enerland.
Good info JRH, I have heard some rumors and such revolving around the lipo industry as well. Hopefuly technology keeps moving quickly and the prices come down too!
He is probably right. But if he did them himself he would not have the satisfaction of paying me! HAHA!
skellyo
skellyo's Avatar
03.13.2009, 10:44 AM
Don't mind Hippie...he's off his meds again.
03.13.2009, 11:07 AM
I figured he had to be on something...
J/K
03.13.2009, 11:17 AM
Ok, more pics on skellyo's packs.
Here are a few shots of the 5s pack with the tp balancer wiring removed and split into a 2s and 3s pack.
03.13.2009, 11:23 AM
And a few more pics of the 2s and 3s pack after I put the hyperion taps and taped them up.
Note the green masking tape. I use this as it does not leave any glue residue, like electrical tape does. It is also quite stretchy, and does not shrink or grow. Plus I have dozens of rolls of it at work. I use it to cover the individual cell tabs and then layer it up on the ends for added protection. I sometimes wrap the packs in thin clear packing tape, but these cells have a double sided tape that holds the cells together so they are attached to each other well. Cell shifting is a big problem, so it is good to make sure the cells are held together well.
03.13.2009, 11:29 AM
Another little bit of info. Note that I have a small ziptie on the balancer wires. I do this to keep them together and provide a bit more strength. On the enerland cells that have tabs on each end some of the tap wires run along the side of the pack. I tape them down to keep them in place. The tap wires that attach on the top of the pack are looped under the tap to give them some strain relief. Some people are a bit rough with balance taps and this helps the wires survive and not tear off where they are soldered. Seems like zippy and venom packs are bad about this, as the align style taps usually have the thinnest wires in the balance harness.
Just a little info I though I would share.
And these packs make an even 200 enerland based cells that I have worked with in the last 2 months! I am sick of soldering, my big gun style iron that I use for the large wires is about worn out! God only knows how many packs I have fixed/altered by now. Must be at least 250 packs. Seems like all I do is solder on lipos!!!
rchippie
rchippie's Avatar
03.13.2009, 12:53 PM
