I'm thinking of doing a Muggy conversion. Can I run a Neu 1527 1D, MMM, and 4S 6000MAh 20C geared for 40? What do you think? Please, help me understand more about the amp draw that you all refer to in setups.
I am thinking a 1521/1y with 6s lipo would be plenty, the motor will have a higher amp draw then a 1515 motor of the same kv so you might want a higher mah rating than 5000
A 1521 1y would be the best bet. I am guessing by 6000 20c you are refering to maxamps? No way that pack will stand up to a 1512, let alone a 1521. You need something good, like an enerland cell based pack. 5000 25-30c 6s lipo will do. FP, TP, polyquest, polyrc, neu energy and hyperion are what to look for. Mike also sells some packs under the rcmonster name that perform well.
From what some of the other members here have found, the 1d 1527 is an "amp hog" so it may be best to try to swap it out for a lower kv motor, and then run 6s. It will pull so big amps on 4s. You will have to run at least 2 4s packs in parallel, something like the 4500 30c enerland cell packs, to give you enough amp reserve. Not sure what esc you plan to use, even the MMM may not be enough...
the 1527/1d is capable of 2250 continous watts and if you ran 6s that would be in the neighborhood of 100 amps but the kv would be too high for 6s at 4s you would be pulling 156 amps...everything would be VERY toasty
I've got a 1515 2.5d in mine on 5s. It's easily as fast as the truck (or the driver) can handle. Anything bigger is just overkill - not that there's anything wrong with overkill.
Watts divided by volts will give you amps. conversely amps times volts gives you watts. You also have to figure that the system will only be around 70% efficient, so your batt needs to be that much more capable.
Say you have a motor that can pull 2000 watts. On 6s lipo your batt would need to be capable of 90amps - 2000/22.2=90
But you have the efficiency to think about, so 90/.70 = 128, so you would need a batt that could deliver aroound 128 amps cont, and not drop the voltage below 3.7v per cell. Most lipos do experience voltage drop nearer 3.2v per cell and heavy load.
So something in the neighborhood of 150 amps cont will cover voltage drop, efficiency losses, and poor math...
Always good to state your lipo choice too, as many packs are rated much higher than they can deliver, and the only way to know that is thru experience...
That is what I was looking for. Now, I want have to answer so many questions. Why has Brian G. not added something like this to his speed calculator section.
To calculate what your batteries are cappable of is C rating/1000 * MAh = continuous amps ability of your batteries. Here is where experience comes in because the C rating varies from company to company and some fudge here. Am I right? I think I getting this now. I have a Master's degree in math, but it is for education not engineering/electrical. I'm a math teacher/assistant principal and I share a lot of what you guys teach me in the classroom. The students love it. Several are helping me build a huge track on my land. We live in the country.
