brushlessboy16
brushlessboy16's Avatar
03.16.2009, 10:05 PM
It will not, the bearin race on the genisis spur gear is made for a 10mm ID bearing- i tried.
Just about any 8th scale spur gear will work on it with minor mods.
93firebird
03.16.2009, 10:18 PM
check out these links. From what I see the bearings are the same part number used on the front/rear and center diff of the genesis as well as the matrix center diff. That bearing is part number g73914 which is 8x16x5 in size.
http://www.cenracingdirect.com/images/GST77.htm
http://www.cenracingdirect.com/images/MatrixC1Buggy.htm
also note that the back plate part number gs060 found on the matrix center diff is the same as the plate used on the front/rear diff of the genesis, which uses the same housing as the center diff.
Tags
cen matrix
