XSKAPE
03.17.2009, 06:48 PM
I'm also running a set of Traxxas CVD's and snapped my hybrid V2 output shafts.
Does anyone the part number of the revo shafts I can chop down to get me going? Arct1k?
Also has any thought of or tried the genuine Hot Bodies Out drive Shafts and cups? Removing the traxxas cups all together? I assume the dog bone will slight straight in.
Part number HBSC8064
| UE G3 GorillaMaxx MMM 2200kv Combo | G3R CF GorillaRevo MMM Tekno RC Edition Neu 1515/1.5D/F | Losi 8IGHT-B Neu MMM 1512/1.5Y/F |
sikeston34m
sikeston34m's Avatar
03.21.2009, 11:38 PM
Would these be compatible with the Traxxas cvd's? I wonder how big the ball is on the end of the HB cvd?
Semi Pro
Semi Pro's Avatar
03.22.2009, 12:13 AM
the ball is 7.92mm
the pin is 3mm in diameter and 13.9mm long.
im pretty sure the hb cups will be to short for the traxxas cvd's
on mikey84's emaxx that we modded in lst2 diffs, we had to make hybrid cvds with mip revo 3.3 bones. since the maxx uses shorter bones than the revo im pretty sure you will need even longer bones on the revo.
some of the old ofna buggys used longer diff cups, i will see if i can find some
sikeston34m
03.22.2009, 12:26 AM
the ball is 7.92mm
So will the Traxxas cvd fit the hole in the cup? How much is the traxxas cvd gonna come up short?
Here is an alternative set of cvd's for the Revo. They have bigger balls.
http://cgi.ebay.com/THS-320-CVD-UNIV...QQcmdZViewItem
Would they work with the HotBodies cups?
I'm having the same problem as Arct1k.
I REALLY want to bullet proof the drivetrain on my E Revo using the RCM diffs I have.
