03.18.2009, 04:13 PM
Clean, I suppose...
Q. if you were to remove the mouldings in that area under where the esc is mounted, would it actually fit/sit in there, or is the MMM just a tad too wide?
Jeremy1976
03.18.2009, 04:18 PM
It would sit in there. I figure for now I am going to leave it as is just so I can get out and run it. But in the near future I do plan on getting out the dremel and taking down those plastic pieces and then lining the entire inside with some type of padding and then velcro it down with the zip tie still over the top.
GO-RIDE.com
03.18.2009, 04:35 PM
Is that Mod 1 gearing you are running? If so what are the details on the slipper/spur conversion to run Mod 1? I'd like to run my Medusa 50x3300 5mm shaft in a slash.
E-8ight - Tekin RX8 2000kv/4S
skellyo
skellyo's Avatar
03.18.2009, 05:01 PM
He's running Mod0.8. There's no real need to run Mod1 in a Slash. You can get much better gearing options with Mod0.8 anyhow. Robinson Racing makes a ton of 5mm bore Mod0.8 pinions and Traxxas has about 7 different Mod0.8 spurs available that bolt right up.
