Jeremy1976
03.18.2009, 04:50 PM
lol, I always simply chuck the disc as it is usually outdated. When you go to rev 1.20, you'll see how different the startup routine is. And I would back timing off a bit; the Medusa has enough torque/speed that any addition due to increased timing is not really worth the added heat...
So you think I should set it back to 10? I raised it to 15. The timing that is.
03.18.2009, 04:59 PM
Originally Posted by phatmonk View Post
What is throttle deadband refer to?
Just the "narrowness" of the neutral range. The narrower it is, the earlier it starts to move with just a slight touch of the throttle.
I would, but I try to set my stuff up so it runs as cool as possible without sacrificing performance. It won't hurt anything to keep it higher (as long as temps are ok), but you don't get a lot of extra output. Keep it higher if you want, just monitor temps and maybe experiment to see which setting gives you the temps and performance you want.
