brushlessboy16
brushlessboy16's Avatar
03.19.2009, 10:11 PM
Lookin' good, what chassis braces are those? I have been looking for some for my matrix :).
Also does the rcm mount work with the buggy spur gear?
truggyracer1
truggyracer1's Avatar
03.20.2009, 10:08 AM
if you don't mind me asking which braces are you refering to? the red chassis brace towards the rear? i'm using gene hickerson front and rear turn buckles and ackerman plate just thought you like to know! the center diff is from a matrix R2 its the plastic case i had no fitment issues at all direct bolt in got it from the bay for under $20 theres one on there right now better thn dealing with the old diff i took it all apart took the grease out and added 10k associated silicone fluid should be better the grease i hope??
like to add i'm using the resivoir shocks 50 AE front and 45 AE rear stays pretty planted at my track hope its the same after the diff oil changes gona have to learn to drive it again been a long winter!!!!!!
