Running higher timing on lower pole motors can increase the heat substantially. I ran my Mamba Max 5700 at highest timing and it showed an increase in performance and speed but my ESC, motor, and batteries all ran hotter. I turned it all the way down to lowest and the performance wasn't much worse but the ESC, motor, and batteries all ran cool.
Is it possible to have a suggested value for my 6 pole motor or I have to find it with testing? How can I understand if i got the correct value? do I risk to brake the esc or the motor if i choose a wrong timing value?
thanks
