fastbaja5b
fastbaja5b's Avatar
03.23.2009, 02:06 AM
I run mine on 4s, 20t pinion, 100% punch control and 0 degree timing and it's still a handful.
Say Less, Do More.
skellyo
skellyo's Avatar
03.23.2009, 10:32 AM
100% punch control? That's way too much if you ever jump it. You'll never be able to correct it in the air with that much punch control.
FWIW, I think 4S with the 20T stock pinion is about perfect for bashing. If you haven't done so, put some tires on other than the crappy stockers. The reduced diameter and reduced ballooning of better tires will make a world of difference in handling.
Ascender
Ascender's Avatar
03.24.2009, 11:24 PM
I'm gonna pick up either Crimefighters or BowTies premounted on some discs. I'm also gonna grab something in the stock size to mount on a set of Axial beadlocks.
skellyo
skellyo's Avatar
03.24.2009, 11:37 PM
Crimefighters are good all-round tire for bashing or the track. Stick with the M2 compound if you will be bashing with it though.
Also, IIRC, the Axial beadlocks are all larger diameter wheels (40 series), so you'll need some Pro-Line 40 series tires or equivalent to mount on there. I'd recommend looking into either Mashers or Mulchers depending on where you do most of your driving. The Mashers are good for all purpose and the Mulchers are really good for grass and some dirt.
