E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.23.2009, 02:22 AM
Originally Posted by Unsullied_Spy View Post
Uh ohh, I'm assuming those were 8k packs...I've got 2 2s 8k packs that I just E-Mailed them about, too bad I hadn't run across this forum BEFORE buying $400 worth of junk lipos.
As for Zippy vs. Maxamps, after owning 4 Maxamps packs and 1 Zippy I'm convinced that Zippy is the way to go if you aren't made of money. Sure they have a few problems here and there but for the price you get a good lipo. People try to compare them to Enerland lipos too often, they're half the price of an Enerland and the performance is good enough for what you pay. Mine held it's balance much better than any MA pack I've ever owned and ran cooler while providing good power and it was my own fault that it got messed up--I have no reason not to buy them again.
The packs in question where 6000mah 20/40C. I had 4 packs, 2 pairs. The first pair that I bought I ordered with the hard shell shrunk wrap in and no warranty, this pair I never had a problem with. Second set I ordered when they ran a special to get the free warranty, this set went way out of balance! Over 0.5 volts out of balance, it took almost 8 hours to get the pack balanced!
03.23.2009, 10:56 AM
...Over 0.5 volts out of balance, it took almost 8 hours to get the pack balanced!
If I ever get a cell that far out of balance, I would probably rig up something to charge the low cell(s) individually at something like 1.5A. Still slow, but far faster than balancing at ~300mA.
03.23.2009, 11:05 AM
I have done this with a balancer harness pigtail and some alligator clips.
I did buy this charger recently: http://www.hobbycity.com/hobbycity/s...Charge_Capable
It charges each cell separately. Max output is about 1.8amps (on the 2 amp setting) and it charges to 4.16v. Perfect for getting a mixture of cells balanced out when building an oddball pack, or balancing out a pack with big voltage differences. For the price it is great, highly recommended.
