Shark413
Shark413's Avatar
03.23.2009, 02:58 AM
As far as your buggy motor temps, have you tried running without the smart diff?
bdebde, I ran the first day with a standard diff the second time out was with the Smart Diff and both times I had temps that I felt were a little high. Some runs would be fine, then there would be a run where the temps started out fine then they shot up into the 170+ degree range. I never had temps like this using my 1512/2D or 1515/1.5D in my other buggies. So yeah may be it has something to do with the SD, I'll try the 1515/1.5D which I know runs cool and see how it works in my Losi using the SD.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
