speedemall
03.23.2009, 10:19 PM
Originally Posted by jayjay283 View Post
I dont know what your gearing is and if 1 speed or 2, but MMM/2200kv- 4s in a Kyosho gt wont go nearly as fast as the nitro versions, he will be going high 40's .. I agree with Bdebde, throw a 6s /25c-30c/5000mah. Hit high 60 low 70s easy .. Gear for 100+mph speed runs...
Gotta measure your battery tray to find what will fit
http://progressiverc.com/6S_Lipo.html
I have done the single speed conversion running a 44t spur and whatever tooth pinion comes with the CC 2200,I am still waiting for the Castle setup to arrive
bdebde
That's All Folks!
bdebde's Avatar
03.23.2009, 10:23 PM
I believe you will need to order another pinion. If I am not mistaken, you have mod1 spur, the pinion included with the castle set up is 32 pitch.
speedemall
03.23.2009, 10:55 PM
would it be safe to run two 3s packs side by side with a Y harness? I really don't want most of the weight on one side of the chassis from using a 6s pack. Any benefit running one setup over the other,both packs being identical on the dual setup? Obviously it would be easier to charge one pack being that I have only one charger and won't have to wait for two.
jayjay283
jayjay283's Avatar
03.24.2009, 10:00 AM
Side by Side would be great if you have the room. 2x 3s lipos 5000 mah or 2x 6s lipos 2500 mah. if you have the room.
It wouldnt be "THAT" off weight with 1 lipo, approx. 850 grams for a 6s 5000 lipo,... otherside 340g for a 1515, 50g for a servo etc..
some here have pics of their buggys/truggys with dual RCM trays and the RCM mount on the front diff mount so the motor sits at the front drivers side... Cant find a pic ATM..
speedemall
03.24.2009, 11:30 AM
I have an equinox ,would I have to get another balancer for a 6s? If so what do you recommend??
03.24.2009, 11:32 AM
Yep, the equinox is only good for 5s. I like the hyperion lba10. What charger do you have?
speedemall
03.24.2009, 11:34 AM
an ICE
