How big are the Losi aftershock LST LST2 or xxl Shocks
SpeedAssault
SpeedAssault's Avatar
How big are the Losi aftershock LST LST2 or xxl Shocks - 03.27.2009, 12:37 AM
Hi people I need some help on finding a suitable set of shocks for my custom emaxx/revo/lst 8 lb 1/5 monster sedan
I was looking at the losi shocks, but told they are 35mm 1.4' in Diameter and 6" long is that true..?
Do you what size they are or what good shock I should be using ?
Use:Mild small jumps, but mostly street and hard pack driving
comments, suggestions, tips,feeback greatly apreciated
thanks you
Finnster
KillaHurtz
Finnster's Avatar
03.27.2009, 12:40 AM
Freaking huge. Measurements sound right, tho I didn't check them.
dunno on the rest...
Metallover
RC-Monster Spudgunner
Metallover's Avatar
03.27.2009, 12:46 AM
The shocks on my 8ight buggy are 95/115mm long (f/r) and 25mm+ diameter.
Thats 3 3/4"- 4 1/2" and almost 1 1/4" in diamter.
That means the area of the top of the shock is about 982mm^2, am I right?
Unsullied_Spy
Unsullied_Spy's Avatar
03.27.2009, 02:57 AM
I doubt they'll fit inside those Maxx arms without modification. They're bigger around than the shocks on my Baja 5b
Bad Karma
03.27.2009, 03:59 AM
They wont fit in the maxx arms, you can make them fit but it requires a bit of modification and will weaken the arms, some searching and you might be able to find a post where someone took some Al arms and modified them to use LST shocks.
Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
03.27.2009, 04:14 AM
Check out the following site............
http://monster.traxxas.com/showthread.php?t=424397
Should give you a bit of info on the shocks with the Maxx.
I like it.......I LIKE IT ALOT!!!!!!
Byte
03.27.2009, 08:43 AM
I just took one of my LST Shocks. And yes, they've an 1.4inch diameter and are 6.2 inch long.
Just wanted to share this pic, it's from my Traxxas Rustler VXL with the LST tire and a Shock from the LST
jayjay283
jayjay283's Avatar
03.27.2009, 11:24 AM
Heres a thread on RCM with alot of good pics where we went through a bunch of shocks including LSTs, 8Ts powestrokes etc for the emaxx http://www.rc-monster.com/forum/show...ght=LST+shocks
or this on TRX forum
http://monster.traxxas.com/showpost....8&postcount=17
Just noticed Overkill had this about covered, yes im a lazy 1 eyed thread skimmer
03.27.2009, 11:58 AM
FYI: I have started compiling a list of shock dimensions on my site: http://scriptasylum.com/rc_speed/_shocks.html
If anyone has anything to add, post it in the R/C Calc sticky please...
SpeedAssault
03.27.2009, 05:16 PM
WHeew , Thank you Everyone !
Very useful info
Looks like Losi 8t 8eight is a popular size and affordable
Surprised that Aftershock is 6" long
SpeedAssault
03.28.2009, 01:36 AM
I'll see if I can make a size listing and add it to the link posted earlier
OFNA Ofna LX One shocks
Front Shocks Measure 103mm C to C extended 4"
Rear Shocks Measure 123mm C to C extended 4.8"
Seems these would be just right
How do you guys like the THe LOSI 8eight fronts ? they are much shorter
