DX2.0 and XL-5 issue
jacobsjo87
DX2.0 and XL-5 issue - 03.24.2009, 06:42 PM
I just got a reciever so now I can use my DX2.0 with my slash. The slash is all stock. I put the reciever in and got it bound to the transmitter. So now I am trying to calibrate the esc(XL-5) and the transmitter. I followed the instructions and I have done this process many times with other cars. So I put the esc is in calibration mode it flashes, and I give it full throttle, it recogonizes full throttle and flashes twice. So then I give it full reverse as instructed. For some reason it is not recognizing that I am giving it reverse throttle. I hold it there for a long time and it never gives the confirmation flash. Any help would be appriciated. I can't seem to figure it out.
03.24.2009, 06:46 PM
make sure all end points are set to 100% and trim is 0.
jacobsjo87
03.24.2009, 07:06 PM
I have checked and they are all 100% and trim is zero.
orso76
Lightbulb 03.26.2009, 10:22 AM
I had the same problem with my DX2.0/SR3000 and Mamba Monster (V2/V3).
I solved with the Spektrum Voltage Protector SPM1600:
http://cgi.ebay.it/SPEKTRUM-SPM1600-...3286.m63.l1177
http://cgi.ebay.it/Low-Voltage-Prote...3286.m63.l1177
http://cgi.ebay.it/Spektrum-Voltage-...3286.m63.l1177
...on Ebay there are many
http://www.spektrumrc.com/Products/D...ProdID=SPM1600
Ciao,
Lorenzo
1maxdude
03.27.2009, 05:14 PM
Does the XL-5 like things set at 50/50? For some reason, I recall calibrating issues with my old xl-5 due to having it set at 70/30.
jacobsjo87
03.28.2009, 01:25 AM
I reset the controller and started fresh. It calibrated on the first try. Im not sure what was wrong but its good to go now.
