jsr
03.28.2009, 02:01 PM
What mount did you use? I don't see a mount on Mike's site for the Raze or Raze ST.
Oh, if you make battery trays, I might be interested for the Raze ST.
How much does your rusty weigh? There's quite a few E-Savage guys running the 3300kV 50mm Medusas on 3s with no probs. Temps seem to run about 140F on the motor which seems normal for Medusas. It sounds like you like a lot of power so I think you'd be better with either keeping the 2000kV 60mm on 4s in there if you don't think it's too powerful, or getting the 2200kV 60mm on 4s or the 3100kV 60mm on 3s.
Wouldn't the 2200kV or 2000kV 80mm Medusa be more equivalent to the MMM 2200kV?
Raze ST Truggy
03.28.2009, 04:23 PM
I bought the 80-1600 becasue I thought it would be a good 6S motor and I already had a MMM. Then I went and bought a MMM 2200 combo so in all reallity I'll probably try both and how they are.
I think I'm going to buy a 50mm when I order another raze mount. I have not used the mount in my truggy yet, but I think it will work fine. Gearing might be a little more limited though. When I convert a Raze Truggy I'll post up how it work s out.
-Brian
