Joey
The Big Cheese
Joey's Avatar
03.28.2009, 03:48 PM
Originally Posted by scarletboa View Post
there are some monster sized motors on hobbycity. i'm most likey going to use a kb45 series motor. i've seen people get tons of torque with the L motors. the XL motors are just SICK! a feigao xl motor is 36x74 while a kb xl is 45x78. the only downside is you will need to either find a 30mm spaced motor mount or make one with 30mm spacing for the mount screws.
Yeah the KB45 is a beast, but Im going to stick with a 36mm diameter can I think, I believe that will be more than enough power for me! If I want more I can just make a new motor plate :)
Joey
The Big Cheese
Joey's Avatar
03.28.2009, 10:04 PM
I got the axles on and the shafts in and everything is pretty much good to go...
Well I just rolled it around a little and moved the wheels with my hand, and there is a TON of resistance. I know its coming from the diffs, but not from the gears. I think its from the green goo thats on the diff casing and on the big bevel gear. The little pinion gear now has all the goo on it too and its really thick, so I think thats creating the resistance. Im hoping that after the first time its run the goo will get flung around and will barely be on the gears letting it move alot more freely. Does anyone else have this problem? Does it go away after the first run?
__________________
littlegiant
03.29.2009, 01:40 AM
__________________
Could be a case of over tightened diff housings (If you are using plastic gear housings). Try loosing each screw for half a turn.
Joey
The Big Cheese
Joey's Avatar
03.29.2009, 03:45 PM
Thanks littlegiant Ill check it out.
Just to make sure, the buggy/truggy pinions are usually Mod1 48p right? Im having a hard time finding a pinion like that under 10 bucks.... :confused:
More pics...
Update with pics
Joey
The Big Cheese
Joey's Avatar
Update with pics - 04.16.2009, 07:33 PM
Getting there....
Update with pics
Joey
The Big Cheese
Joey's Avatar
Update with pics - 04.16.2009, 07:34 PM
04.19.2009, 02:12 PM
Great truck! I have a couple questions for you. How much have you spend to date? Would you mind making me a list of the parts you bought? Thanks very much!
Joey
The Big Cheese
Joey's Avatar
04.19.2009, 10:36 PM
Suspension arms: --------------------Bought for $13 shipped.
Bulkheads + Diffs + Shock Towers: -- -Bought front and rear for $47.20 shipped.
Bumper + Skid assembly: -------------Bought front and rear for $8 shipped.
X TVPs: -----------------------------Bought for $15 shipped.
Axle dogbones + cups: ---------------Bought for $25 shipped.
Center diff/tranny and mount: --- ----Bought for $27 shipped.
Bellcrank/Servo Saver assembly: -----Bought for $6.50 shipped.
Axle carriers + bearings: -------------Bought for $13 shipped.
Suspension arm hinge pins: ----------Bought front and rear for $4 shipped.
Screw set + misc: -------------------Bought for $12 shipped.
F/R Turnbuckles: --------------------Bought for $6.70 shipped.
Radio box: --------------------------Bought for $8 shipped.
Center dogbones: -------------------Bought for $15 shipped.
Chassis braces: ---------------------Bought for $10 shipped.
Extra screws/hardware: -------------Bought for $8.
17mm hex hub set: -----------------Bought for $10 shipped.
warhead towers + shock mount kit -- Bought for $15 shipped
Total cost so far... ----------------- $235
I already had the shocks, wheels, and servo. Hope this helps!
Joey
The Big Cheese
Joey's Avatar
04.23.2009, 02:20 AM
Im wondering if all the little 4mm holes I drilled in my chassis at some of the more narrow points has weakened it. How easily do these chassi bend?
I decided to redo the center area as I just wasnt thrilled with some small mistakes I made. I ordered some 6061 aluminum and am going to re build my CD and motor mounts. Basically there will be two "C" shaped plates, one for the CD and one for the motor. The CD plate will allow me to mount the CD like it should be, screwed in from the bottom. The legs of the C will screw to the chassis. The motor C plate will have the legs attach to the inside of the TVPs and the body of the C will be facing the front so as to be close to the spur. Maybe hard to follow... have a look.
I dont know why I didnt think of this in the first place, its so much simpler than what I did before and uses many less parts.
