03.30.2009, 10:13 PM
Yeah, that's about right. It's just showing that any extreme is not good. The idea is to match the setup right for proper operation. In case you didn't catch it, the gearing slider plays affects the temp the most.
As to the motor size question: I personally would go for the 80mm. The increased surface area will have better cooling ability and will be less sensitive to less than ideal gearing.
ambryatim
03.30.2009, 10:22 PM
Honestly that was the first thing that I noticed. I input some numbers into your speed calculator and I know it is just a rough guesstimate but, I was wondering if there would be a way to figure in some inertia or weight to see if would show total amp draw or lack thereof.
Oh, wait I think I found it. Is it where you have max amp that the motor can draw???
