Nitro?? BL rulezzz
MMM v3 into therminal + hot motor??? -
04.02.2009, 05:22 PM
Hey,
I was today bashing with my savage, till suddenly the car stopped. I heard the fan spinning and after a few seconds the car didn't moved at all, therminal shutdown...
The motor gets also very warm> 60+ degrees(140 +F). It even becomes more hot when you stop the car, when you drive it cools down....
Who knows what to do? gearing up will make the motor even hotter i think???
Or what else to do to get the ESC cool and the motor a bit cooler.
Greetz,
Joram
Standard is not an option!
04.02.2009, 05:29 PM
It would help if you gave us more info? Is this the motor in your xmod, or your full size electric car? Or maybe a cordless toaster?
04.02.2009, 05:32 PM
loll
your faster than me
04.02.2009, 05:31 PM
for how long did you run..before this thing happen????and what kind of motor it is????
and the setting of your esc???
A smaller pinion gear will help lower ESC temps. But first make sure there isn't any binding in the transmission/differentials/bearings as binding could be the cause of excess heat.
Nitro?? BL rulezzz
04.03.2009, 02:05 AM
@Lincpimp, read the text, i really said i ran with my SAVAGE,
I use a Savöx 4570 motor, 1800kv on 5S lipo.
Drove about 10-15 minutes when it suddenly happened.
The driveline is OK, runs normall....
Settings of the ESC are:
Brake setting: 3
Brake amount: 50%
Reverse amount: 70%
Punch control: disabled
No drag brake
Start power:HIGH
Greetz,
Joram
04.03.2009, 03:09 AM
first thing reduce your start power to the lowest setting, this will lower your temps, and what is your gearing?
04.03.2009, 03:17 AM
You can try lowering the start power to medium and punch control to something like 30%. These two alone should help a lot.
Nitro?? BL rulezzz
04.03.2009, 08:11 AM
I was planning to adjust the start power to medium.
I'm also going tu se an UBEC, so that is also a lower temp. factor!
Gearing is btw, 18/47 (16/47 but I run Cen diff's)
Greetz,
Joram
RC-Monster Spudgunner
04.03.2009, 08:19 AM
The mmm already has a built in, but separate switching bec so using another one won't do anything.
Nitro?? BL rulezzz
04.03.2009, 08:24 AM
It will lower the temps, it is tested!
It is in the print so it makes heat, if you won't use it won't heat the whole thing...
Greetz,
Joram
04.03.2009, 08:41 AM
I'll try to explain again... Escs like the Mamba max and about every other esc that has a built in bec WILL get lower temps from an external bec. The mmm is different then all the other escs. It has a separate bec built into the bottom of the case. The bec shouldn't produce much heat at all...
Nitro?? BL rulezzz
04.03.2009, 09:00 AM
We will see, before problems with the MMM where the Switching BEC....
Don't say my problems are cause of that, but i prefer an UBEC above the BEC from an speed controller!
Greetz,
Joram
04.03.2009, 09:38 AM
Sounds like you got her all figured out then.
04.03.2009, 11:32 AM
The MMM has a UBEC built into it as Metallover stated. If you go with an external UBEC your temps might drop by 1 deg. F, if that. Hardly worth it IMO. And the problems the MMM used to have with the BEC have been completely resolved, so the only reason I can imagine using an external BEC with the MMM is if you have a V1 or V2 MMM.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
