crazyjr
crazyjr's Avatar
04.04.2009, 04:35 AM
I personally would make them 5mm. And, they wouldn't be true L size motors. Even though they'd be 60mm long, some of that length is eaten up by the coil to wire connections, just like the CMS series. So, like the CMS's are "sub-S" size, these would be "sub-L"s. But would be a good middle of the road motor IMO.
5mm is good, but for small 1/10 apps, you need 1/8 so you can use 48 pitch gears. My vote is for both 1/8 and 5mm
SunnyHouTX
SunnyHouTX's Avatar
04.08.2009, 12:29 PM
I would ask for nothing more than adding a 5mm motor shaft option to the current line-up of CM36 motors. CML36 will also be a nice addition as well.
