NoControl
NoControl's Avatar
04.06.2009, 01:07 AM
So it's either impossible or difficult to remove the xh connector, so that all I have is the wires, and the battery, then install them in a hyperion white connector without buying the "special" hyperion connector with wires or the xh board?
04.06.2009, 01:22 AM
The type of crimped on pin that the xh connector uses will not phsically fit and clip in a hyperion connector. You either have to splice the hyp tap on, or remove the shrink and solder a new harness on. I would suggest an adapter, cheapest and simplest way out.
NoControl
NoControl's Avatar
04.06.2009, 01:34 AM
Thanks for the opinion and yea it looks like I'll have too any ways, can't sem to find the hyperion style connector by itself.
Raze ST Truggy
04.06.2009, 07:43 AM
I have a i-max8 charger that uses JXT ballance tabs, and sometime last year picked up some used hyperion lipos from a menber here. I bought some addapters from hobby city that had a female JXT and a male Hyperion.
I think that JXT is the same as align when your looking for addapters. I also have a 2S MA pack that I also got used here (and btw: still works great) which has the same ballance tab as the 3S hyperion lipos that I have and with some pin moving/ shifting around I am able to ballance that with the same connector as I do the hyperions.
-Brian
