Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
mopar1994
mopar1994's Avatar
04.07.2009, 10:42 AM
heres a short video. i cant believe how much power it has andd it wheelies even with the center diff in it. i got some q's about charging my battery. when i plugged the battery in i set the charger to 5s lipo and 4900mah is there anything else i need to set? and when i started charging it,on the bottom right hand side it said that the battery was at like 19 volts. so should i just not charge it since its only supposed to be at 18.5 volts? and how does the charger know when to stop charging?
04.07.2009, 10:48 AM
Sounds like you have it set correctly.
Are you using the built in balancer while charging? I just ask as you need the correct adapter board to charge a fp lipo as it has a thunderpower style balancing tap.
18.5v is the nominal voltage. 21v is the total voltage that it should charge up to on the charger.
mopar1994
mopar1994's Avatar
04.07.2009, 03:17 PM
yes i have a flight power balancer adapter thingy and i was using it and i will let it charge up to 21v. i love this charger by the way!!!!
Tags
conversion, mmm, revo
