Havok Berg Build...
Page 1 of 3
3
Rating:
Havok Berg Build...
Havok Berg Build... -
04.07.2009, 04:17 PM
The shopping list!
Kamakasi Delrin High Clearance links (Front or Rear) : Black
Kamakasi Delrin High Clearance Tie Rod : Black
Kamakasi Delrin Rear Axle Tray : Black
Kamakasi dig tray
JPC HaVoc Chassis
JPC 2in x 2in Skid for HaVoc / HellStrom
JPC Delrin Chassis Brace
Holmes Dig Switches
Amain RRP1013 - Robinson Racing 48P Pinion Gear (13T)
Amain NWA-FR-11 - NewAge Servo Plate Upper Clamp
Amain NWA-FR-12 - NewAge Servo Plate Bottom Clamp
Amain NWA-FR-14 - NewAge Servo Mount
Amain NWA-AXL-SET - NewAge 2 Complete Custom 2.2 Crawler Axle Set
Amain RRP1012 - Robinson Racing 48P Pinion Gear (12T)
Amain NWA-FR-13 - NewAge Servo Plate
Amain AXIA1348 - Axial 6x6mm Spacer (Blue) (6)
Amain SPTSTA30881R - ST Racing Concepts Aluminum Rear Steer Conversion Links (Red)
Amain OFN28008 - OFNA Front Bottom Arm, (2)
Tower LXWVB1 Hot Bodies HB Rover Tire White Rock Crawler (2)
Tower Deans 2 pair
Tower LXHGB7 Traxxas Rod Ends w/Hollow Balls Large Revo (12)
Tower LXWMN2 Lunsford Racing Titanium Rock Grinder Link 4x55mmx3/16Tower LXLYV3 Integy Matrix Pro Lathe Motor 45T Single
Tower LXTVY1 Pro-Line 2.2" Eight Shooter Bead-Loc Black REAR
Tower L5WMM803 Lunsford Racing Titanium Servo Link AX10
CJL HS7955TG
CJL MM / 6v BEC
CJL Revo Red turbuckles
CJL 1200 2s Lipo
RCC Telfon skids
Find all posts by Arct1k
2
04.07.2009, 04:43 PM
WOW, quite the list! Look forward to seeing it done.
Find all posts by magman
3
rchippie
04.07.2009, 05:12 PM
Originally Posted by
The shopping list!
Chris i think you have the wrong pinions. The berg axels use metric gears. Also you have a 12t & 13t pinon . Why the different gears ?.
REAL MEN RUN BRUSHLESS
05:40 PM
rchippie
Find all posts by rchippie
4
04.07.2009, 05:38 PM
Balls they call it metric 48p but it is 0.6
I believe that this what I need Metric .6 Module Steel Alloy Pinions
1112 Metric Steel Alloy 48 Pitch Pinion 12 Teeth $3.50
1113 Metric Steel Alloy 48 Pitch Pinion 13 Teeth $3.50
The aim of the different pinions is to overdrive the front slightly which helps stop the rear pulling the front over...
06:04 PM
5
04.07.2009, 05:40 PM
Need some help with wheels - I'm torn:
- Proline Epic Rears $40
- Proline 8shooter $40
- Eritex $75
- Mayham comps $110
I'm kind of loathed at the moment to pitch up the extra $70 but don't want to waste $40 on wrong wheels either! LOL
HELP
6
rchippie
04.07.2009, 07:02 PM
I guess you got the right ones according to the robinson site . The part #'s you listed are the metric ones .
http://www.robinsonracing.com/catalo...on.html#metric
I went for the MAYHEM wheels because they offer a berg offset . so the truck is not to wide .
07:04 PM
rchippie
7
04.07.2009, 09:28 PM
Update picked up the Tekin 35T's and DNA Stalkers berg offset
8
rchippie
04.07.2009, 09:31 PM
Those are good choices. Are the tekin's hand or machine wound ?. I went with the cheap integy 45t motors for now .
rchippie
9
04.07.2009, 09:37 PM
Looks like machine wound but the only 35t's in stock on the planet - an expensive day...
10
rchippie
04.07.2009, 09:42 PM
It sure sounds like you spent alot
rchippie
11
04.07.2009, 09:48 PM
Well sale of a brushless losi 8 and a converted crt .5 covered it - just
12
rchippie
04.07.2009, 10:11 PM
I sold some stuff as well to build my KK 4.0 berg .
rchippie
13
04.07.2009, 10:19 PM
I kept the AX10 for my son...
14
rchippie
04.07.2009, 10:35 PM
Thats cool that each of you will have a truck to use .
rchippie
15
RCShocker
RC Monster
04.08.2009, 06:28 PM
The shopping list!
Kamakasi dig tray
JPC HaVoc Chassis
Holmes Dig Switches
Tower Deans 2 pair
CJL HS7955TG
CJL MM / 6v BEC
CJL 1200 2s Lipo
RCC Telfon skids
Good Lord
I'm sure you scared someone with that grocery list.
RCShocker
Find all posts by RCShocker
Page 1 of 3
3
Linear Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
Off
