George16
Supermaxx
George16's Avatar
04.09.2009, 08:50 AM
Anyway, I received the Traxxas ESC mount and decided to install one of them on my truggy. I got the mounting plate idea from rootar. I had to move the battery plate half an inch forward to make room for the ESC. Here are some pics.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Jason
05.14.2009, 01:42 AM
im back from trying a feigao 540c 8xl 2084kv on my st-r and motor and esc overheat battery are cool ... im using a heatsink on the motor and I run with no body ... and running on the tarmac ( speed run )
motor : feigao 540c 8xl
esc : mamba max 1/10
gearing : spur 50t pinion 17t
battery : truerc 4s 6400mah 15c
motor run about 175f
esc run around the same temps ...
BEC was disabled...
the top speed was only around 40mph something wrong ?
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 17
Total Voltage: 14.8
Motor KV: 2084
Tire Diameter (inches): 5.5
Tire Ballooning (inches): 0
Motor Current Draw: 83
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 2.94 : 1
Total Ratio: 12.64706 : 1
Tire Circumference (inches): 17.28 inches (438.88 mm)
Total Motor Speed: 29580.5 RPM
Vehicle Speed: 38.27 mph (61.48 km/h)
Effective KV Value: 1998.68
KT constant: 0.65 oz-in/A
Motor Torque: 0.28 ft-lbs
Final Torque: 3.55 ft-lbs
Final Power: 1228.4 watts (1.6 HP)
Jason
05.14.2009, 06:41 PM
